Git User Group
PUSHOK and GIT
The GIT plugin that works with Labview can be downloaded from this URL:
http://www.pushok.com/software/git.html
The instructions on how to use it are almost useless. I am working on a PDF document that will include the instructions that I am using and will have screen shots to better explain the process.
The instructions themselves are below:
WARNING: Create Git folder from tools->source control-> change project.
Then CREATE project. DOES NOT WORK, requires an empty folder.
Create LV project then make it a git folder.
Use tortoise git to make a repository in that folder.
Can't do it any other way.
Items Tab->Project->Properties->SourceControl-> use top item to
connect project to git folder.
Then you can run PushOKClient from Tools->SourceControl->Run...
Message 1 of 1
(5,427 Views)
