GPU Computing
Parallel image processing for high-speed particle tracking
Earlier this year we published a peer-reviewed journal article that describes a new high-speed particle tracking instrument. The article can be found here: http://dx.doi.org/10.1063/1.4802678
The basic idea (relevant to Labview and CUDA) is that the program uses Labview to integrate a high-speed camera and a custom-written CUDA program. The CUDA program is compiled into a DLL using MS Visual Studio. We can call the DLL from Labview using a Call Library Function node. The program takes a stack of (~100) images and finds the X,Y,Z positions of ~10 beads in each image. The algorithm requires some Fourier transforms, and look up-tables, and so is computationally intensive (and perfect for a GPU). As a results of the CUDA implementation, we are no longer limited by the particle-tracking algorithm. We are now limited only by the bandwidth of the ethernet cable that transfers images to the GPU. We use this program on a regular basis to collect data for academic research in biophysics.
We decided to make our source code (Labview and CUDA) completely open-source, and you can download it here: http://www1.engr.ucsb.edu/~saleh/ The program includes a minimum working Labview example that calls a DLL (that calls CUDA functions).
A big shoutout to Andrey_Dmitriev for showing the community how to get a simple CUDA program talking to Labview! Most of the CUDA code was written by Shawn Tabrizi during his undergraduate internship.
Comments and questions on the code are welcome!
(6,697 Views)
This is very interesting. Will read it.
Xsword
(5,916 Views)
