GDS(Goop Development Suite)
Use OpenGDS API CreateClass function to create a class from my own template (based on EndevoGOOP400)
A quick question...
I created my own template based on one of the existing EndevoGOOP4 by reference templates.
When I select "New GOOP Class" in my project I can create a new class based on my own template since this template is shown inside the OpenGDS Create Class Dialog.
So far so good.
Now I want to use the OpenGDS API to create classes based upon my own template but this does not work.
Inside the GDSAPI_CreateClass.vi I cannot specify my own template. Only the default OpenGDS templates can be selected. (Standard, Singleton, Interface by aggregation, Interface by VI Server).
Does anybody know how the OpenGSP API GDSAPI_CreateClass.vi function can be used to create a class based upon a custom template? I'm asking since I want to create a large number of classes this way, and having a possibility to do it programmatically would help a lot!
Thanks in advance for all the help or suggestions!
(2,873 Views)
Can you send your template and I can have a look the issue?
(2,836 Views)
Hi Mikael,
First of all, thanks for your message. I was able to use the OpenGDS API to create a class of my own template but I had to modify the GDSAPI_CreateClass function in order to do so.
This is probably not the way it was intended - but it works for now for me...
If there is a better way to add a custom EndevoGoop4 class template and use the GDSAPI functions to create these classes based upon this custom template - I'm definitely interested to learn about it.
Best regards
(2,829 Views)
