G#
issue while using G#
I am a new user of G#
While i am using the G#, there is a issue with it
when i right-click g#,select G# IDE:Create method. there is no any feedback . in normal status, it must show G#IDE .
my labview is 2019.
could G# developer give me some advise?
(8,826 Views)
So you are saying that the Create Method dialog window does not open?
Has it ever worked?
How did you install G#? From VIPM? What version of G# framework?
I don't understand "in normal status, it must show G#IDE". Can you explain a bit more what you are trying to say? Are you saying that you expect the Create Method dialog window to open?
Certified LabVIEW Architect
(8,820 Views)
Wasn't there an requirement that you need to have saved a project for things to work, as it creates and adds files to the project file? (long time since i did any G#)
/Y
Qestit Systems
Certified-LabVIEW-Developer
(8,798 Views)
Project can be unsaved, G# doesn't automatically resave the project, Methods are not stored in the projects, but in the lvclass file. However, if you add a method then the .lvclass file will be automatically resaved.
I also just tried to create a method and it works just fine with latest G# and LV2019.
(8,790 Views)
Did you solve the problem?
I wanted to add that it is likely a VI in the G# addon that is not compiled for your LabVIEW version or some other faulty installation of the addon that causes this. Isn't there an option in VIPM not to mass-compile at install? Perhaps that option was on?
(8,772 Views)
good news I re install the G in VIPM
The issue have been closed
thank all support me
(8,753 Views)
