G#
Can G# add a clone method?
like C#, class A=B.clone();
Message 1 of 9
(12,116 Views)
I don't see the use? Any split of a string wire in LV creates a clone. When would this be useful?
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 9
(12,110 Views)
i want to know a G# Class value change
Message 3 of 9
(12,107 Views)
split of a string wire  of G# class point to the same instantiation
Message 4 of 9
(12,100 Views)
In C#, you can clone an object if the class implements the IClonable interface. This clone feature is already implemented in G#. There is a util method in the G#Object.lvclass in the utils folder called. G#Object_Clone. This should be what you are looking for.
There are a lot of advanced utils methods in G# that are not in the menues.
Mattias
Message 5 of 9
(12,094 Views)
could you tell me where is the clone VI?
thank you!
Message 6 of 9
(12,089 Views)
Message 7 of 9
(12,085 Views)
Accepted by topic author yanzhanglin
This is the path to it <LabVIEW>\vi.lib\addons\_AddQ\G#Object\utils\G#Object_Clone.vi
Certified LabVIEW Architect
Message 8 of 9
(12,077 Views)
Thanks!
Message 9 of 9
(12,043 Views)
