G Web Development Software
Graph Hover Format for Time Axis.
Recently in web page, showing value while hover the mouse pointer over a Curve is useful and user friendly.
G web also provide Hover Format field on Graph's Plot's Properties.
Question:
How to format the Hover (toolstip) value for date-time or relative-time format value?
(2,940 Views)
Referring to the <DeployedRun.min.js>  file, we found code as bellow:
            hoverEventHandler(e, t, i) {
                if (this.dispatchPlotHoverEvent(e, t, i) && i && this.plots[i.seriesIndex]) {
                    var n = i.datapoint[0]
                      , r = i.datapoint[1]
                      , o = this.plots[i.seriesIndex].hoverFormat || "{0}, {1}"
                    this.updateHoverTooltip(o, i, [n, r])
                } else
                    this.hideHoverTooltip()
whereas the updateHoverTooltip is defined as bellow:
            updateHoverTooltip(i, n, r) {
/**** referring to the caller function above:
* i <= is the Hover Format o
* n <= is the plot i
* r <= is the data series [n,r]
                let o
                if ("string" == typeof i)         // if hover format is string
                    o = this.format(i, ...r)
                else if ("function" == typeof i)  // We can Assign Function for Hover format? But How?
                    try {
                        o = i(...r, n)
                    } catch (e) {
                        return void t.error(e)
                var a = n.pageX >= this.clientWidth / 2 + e(this).offset().left
                  , s = n.pageY >= this.clientHeight / 2 + e(this).offset().top
                e(this.tooltip).html(o).css({
                    top: n.pageY - e(this.tooltipHolder).offset().top + 5,
                    left: n.pageX - e(this.tooltipHolder).offset().left + 5
                }).toggleClass("on-left", a).toggleClass("on-top", s).show()
 focusing on the hover format part of  above code:
                    try {
                        o = i(...r, n)
                    } catch (e) {
Is it possible to assign a function from JSLI <Script.js>  or webvi function to the hover format?
any example accordingly?
(2,860 Views)
Accepted by topic author ThamS
Finally, we created the JSLI but for the Absolute TimeStamp, so far.
[The example Code is Attached]
The tooltip Hover Format could be set:
- Programmatically using string wired to the diagram, otherwise if disconnected or empty string
- From the Plot Setting Property Panel, otherwise if empty
- using the Default pattern : {1}, {0}, whereas
{1} represent Y Value
{0} represent X-Value, suppose to be Absolute time in this case
It is recommended to Call the gvi Node  after the number of plot are defined/presented on the Graph.
Example of UsageExample of Usage
Sub gviSub gvi JSLI NodeJSLI NodeJSLIJSLI
here is the JavaScript looks like:
(2,794 Views)
