G Web Development Software
ComboBox default value
Is it me or there is no default value for ComboBox and you have to set it up manually via its properties?
Ch
(3,235 Views)
Accepted by topic author _Chris
You can configure the default value of a combobox by selecting a value from the combobox dropdown / entering a value, right clicking the control, and choosing "Make current value default". See the following:
Milan
(3,231 Views)
That option does not appear to be available when the combo box is within a cluster.
(3,196 Views)
The top-level cluster value is what represents the value of the whole cluster (which includes the children). To set the default value of a control inside the cluster you have to change the value of a control inside the cluster and then set the default value of the cluster as a whole:
Milan
(3,190 Views)
Thanks again for the animation.
I was looking in the panel on the right since other controls have the option to set the default value there.
Still need more time to adapt.
(3,185 Views)
