Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
problem with exe file
this is my problem: I finished to do my project and I made the installer. When I try to launch the exe to the customer PC, the file don't find some .ctl control. I have the some problems if I disconneted the type def (option in exe) or if I add the control in the exe. In this second case If I add the controlls in the data folder I can relink the files in the exe and so it run.
Messaggio 1 di 2
5.406Visualizzazioni
Hi Fabio,
I did a simple test creating a project with a VI using a type-def control: the executable worked correctly also on a different PC where the ctl file was not actually present.
Did you set the ctl files as "Always included"?
Bye,
Licia
P.S.: I know that you have also opened a service request: an application engineer is already working on the issue and is in contact with you.
Messaggio 2 di 2
5.400Visualizzazioni
