Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
convert a set of pdf files into XML files
I would like to create a VI to convert a set of pdf files into XML quickly and easily. Wondering if you can convert a pdf file in XML tools provided by LabVIEW and how to do this?
Thank you in advance for availability and kindness.
Messaggio 1 di 2
5.829Visualizzazioni
Hi Francesco,
you will have to read the text out of the pdf document and write it to xml file using the xml functions.
You could try to follow the suggestions in this post.
I hope it helps!
Bye!
Licia
Messaggio 2 di 2
5.802Visualizzazioni
