Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Modifica Proprieta degli Stack plot con i property node
I need to change the properties of the
Stack Plot graph through the property node but the change is reflected only on the last of the graphs of the Stack Plot, I would set the minimum and maximum range of the ordinates of the graphs,
thanks
Luca Ferrante
Messaggio 1 di 2
5.923Visualizzazioni
hi Luca,
in the property node referenced to the waveform chart you have to set the parameter of
Active YScale->YScale Maximum
Doing so, all the plots would be modified.
Simone
Messaggio 2 di 2
5.911Visualizzazioni
