in data 02-24-2011 04:34 AM
I ’m trying to use the NI DAQ 4431 to generate and acquire a signal at the same time.I’ ve been trying to do that with the DAQ Assistant but it seems like it can be use only to generate or Acquire but not at the same time.Is there a way to use the Daq Assistant as generation and acquisition function at the same time?thanks a lot
in data 02-28-2011 04:29 AM
You could find different examples VI that demonstrate how to continuously acquire and generate data at the same time in Find Examples >> Hardware Input and Output >> DAQmx >> Synchronization
Regards
in data 02-28-2011 10:09 AM
thanks a lot.
