cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Null Offset not working as expected
I am measuring 3 strains (each set up using a half-bridge configuration). After starting the program, the gauges have an initial non-zero readings, however when I select null offset, then apply, the readings do not go to zero. They occasionally get close to zero, but tend to hover at some value between 20 and 200 microstrain. What am I doing wrong here?
0 kudos
Mensaje 1 de 1
266 Vistas
