FlexLogger
DO Rate
I'm trying to get two DO channels to trigger together off one event, but they don't activate at the same time.
I have a boolean value that's changing at 10Hz, and has four events triggering off it.
If this is working correctly, the two outputs should switch together - but instead we get something like this:
(note, the timescale here is 2s)
Are events only meant to run at ~1Hz like tags?
(2,349 Views)
Today, FlexLogger's digital and analog outputs are static and based on tags. So you will get similar update rates to tags (~1Hz). The events should trigger immediately but it's the tags that make the output channels less deterministic. We're looking into ways to support synchronized outputs like you're trying to do here so, if that's something you're interested in providing feedback on, we'd love to hear more about your use case. Feel free to send me an email.
(2,283 Views)
Thanks for clearing that up. I'd like to send you an email with more feedback but can't find one in your profile?
(2,271 Views)
