FieldPoint Family
transfer data from cFP to the host
Hi all, I'm using a Fieldpoint cFP 2120 to take data from temperature sensors. I created the VI to read data and targeted it to the cFP from the project. Since I want to store these data,  I saved them in file in the cFP, but  I want to see them from the host; so I have some questions:
- How can I transfer the saved file from the cFP memory to the host?
- I can directly save the data into the host while I'm running the VI targeted into the cFP?
- How can I access to the cFP memory (see the files in it)?
I'm using LV 8.0
thanks
sandrino
(5,185 Views)
You can use FTP to access files on cFP.  See this link.  http://digital.ni.com/public.nsf/allkb/DBA6DBFFECBEC32186256EE50070AF19
FTP will allow you to copy a file directly to your PC.
(5,172 Views)
Thanks, but in the link is said that I have to type ftp://......... in the address bar of the internet browser. The cFP and the PC are directly connected via ethernet; so how can I do?
sandrino
(5,171 Views)
I've done this on my bench many times.  Give it a try.
(5,168 Views)
OK got it, but when I specify the name of the file to save, I have to give only the name or the name plus the extension ( ex.  "file", "file.dat")? Cause I cant save the file on the PC or open it.
sandrino
(5,166 Views)
I am using Compact FieldPoint 2120 with analog I/O to control a robot arm and i am trying to interface a third party device such as a mobile phone (using Java) to program and control the rotation of each joint of the robot arm. I understand this process can be done through TCP/IP or usign DSC software.
For example:
Hosting on TCP port (?) and use the syntax
[newline]::[joint number]::[degree of freedom]::[set to angle in degrees]::
[arm number] = an ascii value 1 or 2 to determine which arm.
[joint number] = an ascii number value.
[degree of freedom] = ascii value x,y or z.
[set to angle in degrees] = ascii value between 0 and 360.
The true is that i have no clue how to set up the interface steps and i will appreciate if someone can suggest an easy way of doing the above steps and which software to use. I am currently using LabVIEW 8.20 for building the control model for the robot arm.
Many thanks
Bakari
(5,160 Views)
You should be able to drag a copy from the ftp session directly to your desktop or any other location on your pc.
(5,156 Views)
