FieldPoint Family
one iak-file for two programms
Hi
I have a FP1000 and a PF-DO-401 on COM1. I want to use the first ten DO for one programm and the rest (6) with another.
Is this possible? Both programms are running at the same time.
(3,321 Views)
Yes it is possible, when you configure the Fieldpoint Hardware through Fieldpoint Explorer you are basically configuring the datamembers of the Fieldpoint OPC server. A OPC server is able to talk to multiple applications so can use the same configuration file with two programs. I have tested it myself and I had no problems.
Best Regards
Andre Oliveira
National Instruments.
(3,321 Views)
Thank you for your precious answer.
Best regards
Yves
(3,321 Views)
