FieldPoint Family
input parameter is invalid. message
  Hi, there.
used CompactRIO 9004, 9102, so I tried to compile a FPGA.vi
and then like to add to a file at Embedded Project Manager window.
It was Popup a window that is written <Labview : An input parameter is invalid.
VI "Emb_Project_UI.vi" was stopped at node 0x6CE0 of subVI
"Emb_Project_ConvertXml.vi">.
so I coundn't use FPGA target and the program.
Thanks your help.
Have a nice day.
(3,289 Views)
Greetings !
   There could be many reasons for the error. Please try the following.
1) Refer to the FPGA Module training and FPGA User manual to target the FPGA devices from MAX and then from LabVIEW
http://zone.ni.com/devzone/conceptd.nsf/webmain/62b388db80b557028625703700639b89
2) Did you target the FPGA device from MAX?
3) If Yes, did you open up one of our example programs in the example finder from the help examples programs to run on the 9104
4) Also follow the steps where it explains about adding the vi in to your project manager and then viewing it from there
5) If it is your custom built application, you will have to look in to the specific vi's the error message is referring. Check if all the subvi's are present
Hope this helps n good luck
Best regards
Avi Harjani
(3,275 Views)
