FieldPoint Family
how can I use OPC instead of real time
Hi All,
I ve been trying to use OPC instead of Real Time with my Field Point modules. I m new to this system and can you pls type your answer like you re teaching to a little kid.
Thank you very much for your help
(5,625 Views)
Hello ARC_FIU,
You can connect to the OPC Server using datasocket.
The following DevZone article steps you through the process:
Connecting LabVIEW to an OPC Server through a DataSocket Connection
Also, are you using the LabVIEW DSC Module? If so, you have several more options.
You can also take a look at this KnowledgeBase: How Do I Use OPC in LabVIEW?
Take care!
Kameralina
(5,611 Views)
