10-04-2005 09:47 AM
10-04-2005 01:30 PM
FP1001/1001 are Serial network modules which use the Optomux protocol. So, you should be able to, theoretically at least, write your app in any language and on any platform as long as it implements the Optomux Serial protocol. Of course, LabVIEW makes all this easy. You can turn your app into an EXE and run on Unix. But you'll need the run-time engine, obviously.
Hope this gives you some ideas.. ciao!
-Khalid
10-05-2005 05:33 AM
10-05-2005 09:39 AM
In that case you'll need the FP-20xx which can run embedded code. Or the cFP controllers.
Sorry for misunderstanding your question. Regards,
-Khalid
10-06-2005 01:18 AM
10-06-2005 03:58 AM
10-06-2005 04:02 AM
Same thing will apply for RS-232.
You must keep to the [c]FP-20xx controller. It will retrieve data from the FP Modules and you will need to implement a communication loop that sends data over the serial port.
Also, keep in mind that serial communication is not deterministic and this may be an heads-up point as far as RT applications go.
Cheers
AlessioD
10-06-2005 05:03 AM
