FieldPoint Family
cannot find the field point read and write vi's in labview 2009
where is the field point read and write vi's in labview 2009
Message 1 of 9
(9,245 Views)
Under the Measurement I/O palette.  If it's not there, check to see if you actually installed the fieldpoint drivers after installing LV 2009.
Message 2 of 9
(9,242 Views)
I found a link for the Fieldpoint drivers and downloaded them but still do not see the VI's when working on the block diagram.
Message 3 of 9
(9,234 Views)
Hi russell-p,
What version of the FieldPoint Driver did you install?  For LabVIEW 2009, you'll need at least NI-FieldPoint 6.0.5.  Also, make sure that LabVIEW 2009 support is included:
Double-check that the FieldPoint VIs exist at  [LabVIEW 2009]\vi.lib\FieldPoint as well.
Message 4 of 9
(9,227 Views)
I cannot find these VIs either...can't find them in the functions palette or in the vi.lib location......but I can see that the Fieldpoint 6.0.5 is installed in MAX
Message 5 of 9
(8,876 Views)
Did you install the Fieldpoint drivers after installing LV 2009?
Message 6 of 9
(8,869 Views)
Accepted by topic author russell-p
Depending on version of LV, palettes in LV may be context sensitive. Try creating a project and add a fieldpoint target to the project.  Right click on the FP Target in your project and select new >>vi.  Now the FP functions should show up
Message 7 of 9
(8,865 Views)
How to add a fieldpoint to the project? I dont have a fieldpoint connected to my PC.
Message 8 of 9
(7,411 Views)
Hi Yang,
Could you please post this is as a new forum topic?
Bobby Breyer
Message 9 of 9
(7,395 Views)
