FieldPoint Family
cFp 2020 transfer speed blocked to 10M
Hi guys,
I am using a cFP2020 with a crossover cable.
I noticed in the network connection properties that I cannot run at 100M (half or full duplex).
I checked the connection in MAX but it is set to 100 Full Duplex.
When I select 100M Half or 100M Full Duplex, I cannot connect to my controller.
It works only in 10M Half and 10 Full Duplex.
The cable I use is homemade. It is UTP cable (only cable I have in store) that I connected
as a crossover 10/100 Base TX cable
Connector 1
Pin
Connector 2
 Pin
TX_D1+
1
RX_D2+
3
TX_D1-
2
RX_D2-
6
RX_D2+
3
TX_D1+
1
BI_D3+
4
BI_D3+
4
BI_D3-
5
BI_D3-
5
RX_D2-
6
TX_D1-
2
BI_D4+
7
BI_D4+
7
BI_D4-
8
BI_D4-
8
Does somebody know why I can't establish a 100M link?
Thanx
Dai
Dai
LV 7.1 - WIN XP - RT - FP
(3,042 Views)
Problem solved...
But weird solution.
I changed the configuration in MAX to 100 Half Duplex while having 10 Half in XP
Then back to Full Duplex in both and it worked!!!????
Not convincing...
I have a FP2010 to install... I'll keep that in mind.
Dai
Dai
(3,039 Views)
