FieldPoint Family
cFP-Quad-510 is slow to update
Hi:
I think I may allready know the answer to this question, so here it goes.
I am using cFP-2220 with AI-112 (3S/s), AO-210 (200S/s), DI-301 (1KS/s), DO-401 (20KS/s), Quad-510 (1MHz), SG-140 (1.1KS/s), RLY-423. I think the one is causing my update delay is the AI-112 is the slowest at 3S/s. Is there a way to speed the update of the Quad-510 without changing the AI-112 to a AI-118 witch it has a 10.42KS/s.
The cFieldPoint only has the minimal software install. I try to install more into it but when I do that I can not communicate with the cFieldPoint. I am using LabView 11, FiedlPoint 6.11
(6,319 Views)
Could you please explain us why you think module AI-112 is the one causing the slow to update on QUAD-510?
These are independent modules.
Miguel Fonseca
(6,300 Views)
Hi:
Well I thought since is the slowest it is affecting the entire system speed. If his is not the case what is making the system update to be slow.
I am running a while loop continuously collecting data, encoder position is only getting update 3 times this happens in my programming PC. I want to see if this issue appear in the PC that will be running the exe file. In that PC I get  FPLVMgr.dll not found also NI_TGT.dll not found  but this are present in my programming PC
I am using Windows XP3, Labview 2011 f2, FieldPoint 6.0.11
(6,296 Views)
