FieldPoint Family
Why do I received error code 32812?
I get an error code of 32812 in either FP Open or FP Create Tag, what does it mean?
(7,090 Views)
FieldPoint: The specified tag name was not found.
Make sure the resource you are after shows up in FP explorer before trying to access it.
Ben
(7,089 Views)
The error code of 32812 is usually returned in one of two situations. In certain versions of FieldPoint Explorer (2.0.1 or earlier), 32812 could be returned from FP Open if the addressed devices were serial modules and the serial port could not opened (in 2.0.2 and higher, this is changed to 32830 "Unable to Bind to Comm Port". More commonly, the 32812 code is returned from FP Create Tag due to the fact that the item specifed by the string inputs (Comm Resource, Device Name and Item Name) do not match the names in the IAK file. The strings must be exact matches and are both case and space sensitive.
(7,089 Views)
