FieldPoint Family
Using UPD Write VI in Labview RT cFP 2120
I am using the UDP Write VI in cFP 2120 RT However, when the network cable is unplugged from the RT this VI does not report an error 59 which it does when i run the same code on my Computer and disconnect the network cable.
Is it that the UDP VI do not work in RT.
Attached is the VI for reference, using Labview 8.2.1.
Kindly help.
Thanks in Advance.
Naru
Message 1 of 1
(6,571 Views)
