FieldPoint Family
Two Field Point (1601's) simultaneously?
How do I use two Field Point network Modules simultaneously to facilitate more than 9 FP-data modules?
(3,478 Views)
You would use 2 FieldPoint (FP) network modules the same way you would use 1.  Simply use a FP Read.vi or FP Write.vi with an I/O Point assigned.  You will need to use a separate FP Read or Write VI for each module you want to sample from.
Does this answer your question?
Sean C.
(3,472 Views)
Absolutely.  Thank you much.
(3,458 Views)
