FieldPoint Family
Transmitter Interface?
Dear Support:
I bought a FP-1000, FP-AI-100.
And I have two temp/humid sensor, Manufacturer and Model is below.
How to connect a those sensor to FP-AI-100.
Please Help me.
Thank you.
1. DeltaOHM (http://www.deltaohm.com) / Model : HD9008T
2. VAISALA (http://www.vaisala.coom) / Model : HMW60
-CH Lee from seoul Korea-
(3,551 Views)
After looking at the literature, it sounds like you should make the following connections.
HD9008T:
    connect It to Ch0 Iin
    connect Vcc to Ch0 Vsup
    connect IUR to Ch1 Iin
HMW60:
    connect +RH to Ch2 Vsup
    connect -RH to Ch2 Iin
    connect +T to Ch3 VSup
    connect -T to Ch3 Iin
You will need to use the same power supply to prevent grounding issues and this should be connect to V and C of the FieldPoint module.
Please keep in mind that these connections have not been tested.
-Sara
(3,551 Views)
