FieldPoint Family
Pinout for Field Point Module
I need the pinout diagrams. The Termainal numbers for using the Fieldpoint modules so I can make the wiring diagrams.
(3,901 Views)
The pin-out assignments for each I/O module can be found in the Operating Instructions for that particular module. The Operating Instructions come with each module, or can also be found online at www.ni.com\
manuals .
Additionally, each I/O module has an insert on its front, that covers a schematic/pin-out for the module. The back of the insert also provides the pin-out for the module.
Aaron
LabVIEW Champion, CLA, CPI
(3,901 Views)
The terminal numbers change depending on the I/O module that you are using. The terminal numbers for a specific I/O module can be found in the module's manual. You can find the manuals at:
http://digital.ni.com/manuals.nsf/display?ReadForm&lookup=Distributed%20I/O%3E%3EFieldPoint&view=web_productcurrent&node=132090_US
(3,901 Views)
