FieldPoint Family
Modules on cFP backplanes
I think the real question is are you going to be swapping modules in and out of the backplanes after the systems are deployed?  Normally before a system is deployed, I configure it using MAX and the ".iak" file is created and saved.  When the ".iak" file is saved, the target is updated and the "fpbank.ini" file created on the target.  These files are necessary when using the FP vi's to access I/O.
For example.  If a host program uses the FP-Read, the vi needs a valid copy of the ".iak" file on the host.  If an embedded vi on a cFP uses the FP-Read, it needs a valid copy of the "fpbank.ini" file on the cFP.
If you need to swap modules after systems are deployed, you need to figure out if there is a way to programatically create new .iak  and fpbank.ini files without MAX.  I don't think there is a way to automatically detect what is there without using MAX.  I do think that the fpbank.ini could be created programatically if the user told your application exactly what modules were installed in what slots of a particular controller/backplane.  You would need to reboot the controller after the new .ini file was copied in.  The .iak file is a bit tougher because it is a binary file.
Message 11 of 13
(1,351 Views)
Hi HWJ,
centerbolt seems to have hit the nail on the head.  He is correct in all he has said, and if you will be swapping out modules after the system has been deployed you will need to find a way to programatically create a new .iak file.  I don't know how you would do this without accessing MAX.
Please let me know if you have any other questions.  Best of luck on your application, and have a wonderful day!!
Ching P.
DAQ and Academic Hardware R&D
Message 12 of 13
(1,344 Views)
ok.. now I see the picture and all your concerns. I think about it and probably I will change the requirement of the application. Thanks for all the advice so far.
Message 13 of 13
(1,342 Views)
