FieldPoint Family
General server error. : FP Write.vi
I am trying to see a current out of an FP-AO-200 analog current output module in fieldpoint, networked to a FP-1000 and hooked up to the RS232 communication port. I can see the modules fine in FiedlPoint explorer, and I can write values to it just fine. In LabVIEW, I am getting this error as stated in the subject line. Having looked at the help items on the website, the solutions have not helped. The FP Write.vi array input is getting a 1D array for the one channel I have it writing to, so that should not be the problem as stated in the help here. I am wondering is anyone else can help me out. I am running LabVIEW 6.0.2
Will
(5,708 Views)
Will,
The general server error reported by the FP Write.vi is because you are not writing enough values to the tag item that you created in FP Create tag.vi. For example, if you are writing to the "All" tag, then you will need to write to all 8 channels of the FP-AO-200. In conclusion, the array that the FP Write.vi uses will need 8 values, no more, no less.
JohnM
(5,708 Views)
