FieldPoint Family
From LabVIEW, how do I programmatically determine 'open thermocouple' status on a TC-120?
Apart from getting a large value (e.g., 1770 degC) on the channel when doing a FP Read, and getting a 33443 warning:
'Bad channel status reported by several channels. At least one channel is in one of the following states: Unconfigured, Bad Status "A", Bad Status "B" : FP Read.vi'
I can't find any utility VI which would give me a definitive 'open TC' status. Since MAX can report this, I figured there had to be a corresponding way in LabVIEW.
Thanks in advance for responses!
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
(4,329 Views)
Dave,
The 33443 error, "Bad Channel Status", is returned when performing a multi-item read/write when one or more channels is in an error state. If you were performing a single item read/write (e.g. read Channel 0 instead of All), the FP Read will return error 33489, "Open Thermocouple Detected" or error 33487, "Out of Range" (if channels in voltage mode).
Aaron
LabVIEW Champion, CLA, CPI
(4,329 Views)
Thanks, Aaron. I admit I hadn't tried a single-channel read to see if the error got more specific.
I guess I shouldn't be so nit-picky, but it might've been nice if there were a multi-channel 'read status' FP VI. Having to read individual channels (with all those associated FP tags cluttering the BD) just to get status seems a bit inelegant, and defeats the efficiency gains of doing a module-wide read.
Alternatively, this looks like one of those places where returning 'NaN', or '+Inf', '-Inf', on a floating point FPRead, would be appropriate.
I suppose I can do an array test for '>=1770', then manipulate the data to convert open channel readings to NaN. (I like NaN since multiplot charts/graphs handle it as a pen lift, and omit it from aut
oscaling.)
Thanks again!
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(4,329 Views)
