FieldPoint Family
Flow Measurement With Turbine Flow Meter Using cFP
Hi I am trying to measure a flow rate using a Gems FT-110 Turbine Flow Rate Sensor. The cable connection has a Red one that says 5-24VDC, a Black one that says 0 VDC and a Brown one showing a square wave. If I am using a compact Fieldpoint, should I use a Counter like the NI cFP-CTR-500? How do I connect the flow meter to the module? Thank you.
(6,398 Views)
This is a sourcing sensor.  Look at Fig 3. in the manual .
(6,389 Views)
