FieldPoint Family
Fieldpoint executable not reading modules
The executable program will not recognize the FP Modules.  The FP modules are readable from MAX (NI-DAQ7.4) on the target and developement PC.  The original program works fine within LABView 7.1 on target and developemnt PCs. The executable will not work on the development or target PC.
FP-AI-100
FP-TC-100
FP-1000
I have tried re-building the executable per the knowledgebase documents a few times and running on several different PCs with no luck.
All of this leads me to believe that it is the executable build that is faulty not any hardware.  .iak and .dll have been copied from the proper locations.
Any Ideas?
(3,306 Views)
Solution found on Lopez post from 8-9-04
(3,297 Views)
Hi Plasman,
Glad to hear you got things working. Here is the post to which you referred in case anyone else is having the same problem:
http://forums.ni.com/ni/board/message?board.id=110&message.id=1999
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,283 Views)
