FieldPoint Family
Fieldpoint 4.0 and 5.01 in the same machine
Hello:
I had Fieldpoint 4.0 installed and running without problems in my PC before installing Fieldpoint 5.0.1, in order to develop Fieldpoint Systems with LabVIEW 8.2. After the installation of Fieldpoint 5.0.1 my Fieldpoint 4.0 VIs and configuration dissapeared!, and I need them back, I tried to reinstall Fieldpoint 4.0 but a message appears saying a newer version of Fieldpoint is installed.
Is there any way to have both Fieldpoint 4.0 and 5.0.1 in the same machine? I need them both since I have to maintain systems made in LabVIEW 7.0 and 8.2
Any help is appreciated.
Thanks in advance.
Robst - CLD
Using LabVIEW since version 7.0
(3,844 Views)
Robst buen día!
Podrías escribir a nuestra página de soporte para que te podamos ayudar mejor con tu problema?
Te mando un gran saludo y muy bien por usar nuestros Foros de National Instruments
NorSa
NI Applications Engineer Latin America
NorSa
(Former) NI Applications Engineer Latin America
(3,821 Views)
I don't think that you can have two different versions of FP at the same time, but LV 7.0 should work with FP 5 (I have 5.0.0116 and it works find with LV 7.0).
I think that when you install FP you need to tell it which versions of LV you want support for, so if you will reinstall it and tell it to install support for 7.0 as well you should be fine.
___________________
Try to take over the world!
(3,813 Views)
The FieldPoint 5.0.1 CD will only install support for LabVIEW 7.1, 8.0, and 8.2.  Unfortunately, I don't think you will be able to support LV 7.0 and LV 8.2 on the same machine with FieldPoint.  It will require two machines, or moving the 7.0 system to 7.1 (or a higher version of LabVIEW).
-Tommy
(3,811 Views)
