 gx_cully
			gx_cully
			06-01-2009 03:24 PM
Hi all,
I reset my fieldpoint 1601 and now it doesn't connect in max, the greyed out fp icon appears with 0.0.0.0 but when i set the IP and click apply it reads "disconnected - rebooting" for a couple of mins then just "disconnected", I followed the rebooting directions very closely, and i selected an available IP i don't know why this is happening any ideas??
Greg
 Will_S.
			Will_S.
			06-02-2009 06:27 PM
Greg,
Are you setting a static IP or automatically assigning with DHCP? If static, are you positive that it is an available IP? You may want to try using an IP scanner to confirm that the IP is in fact available. Does this happen every time you reset the IP?
06-03-2009 09:41 AM
06-03-2009 09:43 AM
 Will_S.
			Will_S.
			06-03-2009 03:36 PM
Just to make sure, have you followed all the steps listed here? http://digital.ni.com/public.nsf/allkb/50BE7BEA4D5285DA862573370070D30B
There are many troubleshooting steps listed in that article as well. Other questions: when you have the FP-1601 connected to the computer and applying settings, do both lights on the ethernet port light up and blink? Is the status light blinking? If so, how often? When you say that the FP-1601 was sort of working without problems, what exactly do you mean? Have you encountered this before or something similar? What did you do to overcome those issues?
