FieldPoint Family
Error 32800: General server error
When I run a LabVIEW program that used to work ok I get this error. The only thing that has changed since the last time it worked is that I moved my whole setup to a different location and I had rearranged my Field Point devices. Could this be the problem even though I reconfigured everything in Field Point Exploroer? and if so how do I fix it? If it is not the problem, where else should I be looking?
-Thanks
(3,276 Views)
First of all make sure you have checked the points discussed in the following KB.
http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/bae9008fd3505985c1256bff0065b047?OpenDocument
If that is OK, make sure that there is no version mismatch between the FPLVMGR.dll and the FIELDPOINT.dll
or between the FPCVIMGR.dll and the DIELDPOINT.dll.
I would go ahead and check the versions of these files in the new machine and I would make sure they exactly match what you have in the previous one.
I hope it helps
Best Regards
Andre Oliveira
(3,276 Views)
