FieldPoint Family
Alarm Functionality discrepancy
I have an alarm issue for Bridgeview. In my block diagram I have a control wired to an Index Array that is also wired directly to individual set tag attributes that control hi and low alarms, as well as enabling the alarms. I then have a cluster control wired to an unbundle by name cluster function that is then wired to each of the individual set tags described above. These alarms control mass flow controllers as well as thermocouple readings. The MFC's sometimes incur abrupt and drastic jumps and losses in the signal which trip our alarms. These signal variations occur for millisecond to 1 second. How do I eradicate this problem? And if it is programmable (like a signal filter vi) how do I link in this vi?
(3,763 Views)
You would be bettor off posting this question in the LabVIEW Datalogging and Supervisory Control forum as that forum deals with both the LabVIEW Datalogging and Supervisory Control module and BridgeVIEW.
Aaron
LabVIEW Champion, CLA, CPI
(3,763 Views)
