FieldPoint Family
Access denied: This host computer's IP address is not on the target's allowable access list.
Hello Everyone:
I was working normally with my CRIO NI9024 at my work. I went home and when i came back the other day. I tried to compile my working application.
The surprise was that i got a strange message "Access denied: This host computer's IP address is not on the target's allowable access list.".  Now, i can not connect to my CRIO device. I tried to reset all IP adresses , in the CRIO and in my PC machine. What can i do????.
Si todo fuera facil, no estaria aca.
(8,509 Views)
Hi!
This sounds strange...you haven't did any change, right?
Please format the controller, and after try to connect again!
Barbara Pracek
Engenharia de Aplicações
National Instruments Brasil
(8,502 Views)
Accepted by topic author gusarielmanfredi
Yes. That was the solution. I had to uninstall the NI-RIO software on the target. I uninstall everything on the CRIO. then, I install the software again, but i also had to re program the fpga, the host and the target. And i reset also my IP, on the measure and automatition software. I found a big bug i guess.
Thank's anyway. Love National Instrument. Hope to work there someday.
(8,500 Views)
I am having a similar problem on my cRIO-9075 but without success in solving the issue.  I have uninstalled everything from the cRIO, reinstalled and reprogrammed.  I am unsure about what you mean by resetting the IP in the MAX. What I have found is by going into the ni-rt.ini file in the cRIO board and changing the RTTarget.IPAccess="" to RTTarget.IPAccess="+*" I can get everything running.  The problem is when I disconnect the code reverts back to RTTarget.IPAccess="". Any suggestions why this is happening or how I might fix it?
Brendan
(7,661 Views)
Hi Brendan,
Please, if you can't find your question in another board open a new one, so all the users can help you.
This question is already closed.
Barbara Pracek
(7,654 Views)
thanks, will do
(7,650 Views)
