FIRST Tech Challenge Discussions
help
how do you put a .cpp program into a bot?
(4,392 Views)
Accepted by topic author SnoreLax
SnoreLax,
Putting a .cpp file on the robot will not result in a function program because the code must be compiled first.  I would assume since you are doing C++ development you are using RobotC.  You should be able to compile and deploy your C++ code to your NXT from within RobotC.
Cheers,
Mark
Mark
NI App Software R&D
(3,566 Views)
