FIRST Tech Challenge Discussions
Using FTC module with LabView 2010 (Archived)
Accepted by topic author Mepshtain
I've consolidated installation and activation instructions into the following document: Installing and Upgrading LabVIEW 2009 and the FTC Toolkit
Mark
NI App Software R&D
Message 11 of 12
(1,515 Views)
Hi Mepshtain,
actually I encoured the same error as you ...
The solution in my case was ... without installing LabView2009 as follows:
locate the installation folder for the FTC 2010 module:
C:\National Instruments Downloads\FTC Software\2010f4\Products\FTC_Toolkit_900\FTC_Toolkit
there is a file FTC_Toolkit.msi
Install it and then copy all of the new file created in ...Program Files\NI...\LabView2009 to ProgFiles LabView 2010
evoila, My FTC is working as it should.
BLAQmx wrote that: "Unfortunately there is no way force the installer to work with LabVIEW 2010" ... this was NOT true in my case
Cheers,
MMatjaz
Message 12 of 12
(1,515 Views)
