FIRST Tech Challenge Discussions
Motor Encoder Issues in LabVIEW 2010
Our team is currently trying to write an autonomous program using motor encoders. We usually set the distance at 1,000 counts to start. Usually this would only go a few inches on any of our past robots, but this one just goes infinitely. Is there a bug with the new LabVIEW patch that causes the encoders to not read/stop correctly? If so is there a way to fix this issue?
PS I can provide code if needed
(4,142 Views)
Can you please post your code? I'll try it out.
(2,951 Views)
