FIRST Tech Challenge Discussions
FTC Game Error
When I run my code on the prototype seeting in LabView it works perfectly however when I try to run it in FTC Game mode it does not work. This birck says "### DISABLED ###" and has NXT/BAT with numbers in the bottom left. Is there something wrong with my code (I generated it from the controller thing) or my brick? Any help would be appreciated. Thanks!
(6,114 Views)
Did you enable the program? Its only an option in the FTC game mode and has to be set in the remote control editor. How are you connected to the NXT brick?
Kevin Fort
Principal Software Engineer
NI
(4,818 Views)
I'm not sure what you mean by enable the program. If you mean chose the file in the remote control editor I did. I connected via a usb cable.
(4,818 Views)
All I meant is that you selected the program and enabled it (lower right of that same window).
Kevin Fort
NI
(4,818 Views)
Thanks for your help. I selected my TeleOp program from a menue (sorry, the computer with software is at school). So I think that's correct...
(4,818 Views)
Hey Justin,
Have you been able to fix the issue you were having running your program?
Kevin Fort
NI
(4,818 Views)
