FIRST Tech Challenge Discussions
Buttons on FTC Controller
I am trying to use one button to move 2 servos upward in move in 2 different directions at once and than another button to move it down. How can I do that?
(3,585 Views)
Can you be more specific?
In doing so:
  1. Try to label the servos "A", "B", "C", ...  and give clear values for Buttons "1", "2", "3", ...
  2. Identify limits on the servos - you want the servo to move TO position X or TO position Y, or you want the servo to move FROM position X TO position Y in increments of Z (not allowing the servo to go lower than X or higher than Y).
  3. Identify initial starting position - where do you want the servo to be when the program starts (where is the default position)?
  4. Give clear explanations to your actions; for example:
    • "When I press Button 4, I want servos A and B to move to position 127."
    • "While Button 2 is pressed, I want Servo A to move in a positive direction in steps of 5 servo positions (with limits 0 to 150)."
    • "If I press Button 6, I want Servo C to move to position 127, and then when I press it again I want Servo C to return to position 30."
I think what you're asking for is to have a single button to control two servos identically, such that when you press Button 3 you want the servos to move in a positive direction in steps of 5 servo positions (though you don't mention the lower or upper limits, nor the starting position) and when you press Button 4 you want both servos to move in a negative direction in steps of 5 servo positions.
If you give me a specific instruction, I can write you some example code to perform your action.
-Danny
(3,115 Views)
