FIRST Robotics Competition Discussions
strange C-rio behavior/ Driver station status
Strange things are happening with our control system. The enable dongle isn't been seen correctly/ showing the status in the deployed program.
We are running the 3a update and the most recent driver station update.
Anyone have any advice?
Adria Hogan
(6,086 Views)
We were having problems with the update when we tried to run a program and later realized that we had forgotten to set the team number. We set the team number, but then we were not able to switch from disabled to enabled. The fix to this reqired updating the driver station all over again and setting the team number right after we updated the driver station. So maybe that will help you. Your problem sounds similar to ours.
(2,866 Views)
Another thing to check is to see if your code is getting stuck and that the watchdogs are not being fed. Keep an eye out for loops that don't stop executing in subVIs, etc. Turn on highlight execution to see where you might have a hang up.
Joshua B.
(2,866 Views)
