FIRST Robotics Competition Discussions
monitor resolution
Hi all,
i have developed a project and this project contains near by 100 vis. I am calling these vis as per my requirement. Now i have developed this using monitor resolution 1024*768 and when i run this it will cover my full screen of monitor. But whwen i run this same project on different monitor having different resolution the screen is visible but it can not cover the full screen of monitor. It appears in the leftmost side of monitor
So i want that whatever will be the screen resolution my screen should appear clearly on monitor and it should cover the whole monitor .
Regards
Manasi
(11,063 Views)
Hi mom,
You have a few options. First, you have control over the window size, window position, etc. of your VI. You can alter these options from your VI at File » VI Properties. You can then alter properties listed under Window Run-Time Position and Window Size.
I would recommend that you select Position: Maximized under the Window Run-Time Position tab. This would maximize your VI window on whatever computer runs the VI. You can view the other alterable options.
Best of luck,
Kevin S.
p.s. This forum is for FRC (FIRST Robotics Challenge) questions. If you are non-FRC affiliated, you should post future questions to the LabVIEW discussion forum, located here.
(3,783 Views)
hi,
thanks a lot.
But i already tried all these option when i done the settings as u said then the scrreen gets stretched and all objects on screen gets stretched. The scrren also not lloking good. Pls suggest any other solution
Regards
Manasi
(3,783 Views)
Did you try the Maintain proportions of window for different monitor resolutions option under File » VI Properties » Window Size ?
If you still have a problem, I need more information. Can you post a screen shot of both views of your program?
Kevin S.
(3,783 Views)
