FIRST Robotics Competition Discussions
cRio imaging problem
Hello.
When I attempted to image the cRio with the 2010-v19 firmware, the imaging tool connected to the cRio, and got to the step where it uploads the image and then failed with an error indicating that it could not connect to the IP address. I tried to put the cRio in safe mode, format it, and try again, but it got to the step where it uploads the configuration files and then failed with similar reasons. I have checked all of my cabling, and tried both my laptop and the kit Classmate PC, both have the same errors. Is there any way to fix this problem, or is it a problem with the cRio?
(4,462 Views)
Jimzondag,
Thanks for posting your issue on the forums. I think I spoke with you last night for a while on the phone about this issue. We are looking into it and will let you know what we find out. Thanks again!
Ben Sisney
FlexRIO V&V Engineer
(2,998 Views)
I had similar issue w/ imaging.  It had to do w/ firewall settings.  Check out discussion at...
http://decibel.ni.com/content/thread/5746?tstart=0
(2,998 Views)
