FIRST Robotics Competition Discussions
cRIO programming problem
I have run into a problem, I have imiged the cRIO, loaded the Robot Main VI, and pressed run. In the dashboard, it says that it has communication with the robot, and the code is loaded onto it, but moving joystick 1 doesn't do anything to the jaguar in port 1 (I'm taking measurments of the output with a multimeter) And I have a long list in the error log that I copied to a document attached to this.
(7,706 Views)
From the error log it looks like the cRIO isn't recognizing the digital module. Do you have the modules inserted into the cRIO in the order listed on page 11 of this document:http://www.usfirst.org/sites/default/files/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info...
Are you using an FRC 1 or FRC 2 cRIO?
Kevin Fort
Principal Software Engineer
NI
(4,498 Views)
everything is connected correctly, MAX is giving the info code MAXServerUnknownError. And the RSL light is blinking, I think we`r using cRIO 1
(4,498 Views)
Is this the same cRIO you had last year? The module slots did change between last year and this year but it sounds like you did that already. Do you get any errors deploying to the cRIO? If you change the ip address of the cRIO in MAX do the changes persist after saving and rebooting the controller? Is the NI system web server running on your machine-check in control panel->Services)
Kevin Fort
NI
(4,498 Views)
At the moment I wont be able to do much, I`m trying to clear up space on the frc "2gopc" so I can download NI-RIO to work with the robot...
(4,498 Views)
