FIRST Robotics Competition Discussions
Vision Processing Help Please
Hey Jim,
This document shows the document structure on the cRIO:http://digital.ni.com/public.nsf/allkb/BBCAD1AB08F1B6BB8625741F0082C2AF
You will be able to use C:\ to access local memory. If the code you are using is on the cRIO you don't need to worry about addressing it with IP address first but if you are running a VI on your development PC that needs to access files on the cRIO you need to worry about using the IP Address before the directory structure.
Kevin Fort
Principal Software Engineer
NI
Message 11 of 12
(917 Views)
got it...thanks!
i didn't realize that the cRIO had a C-drive directory structure like a PC.   Its working now!
thanks
Jim
Message 12 of 12
(917 Views)
