FIRST Robotics Competition Discussions
Updating Software Problem
I have been running our robot for several weeks now. But when I updated the software
for to the latest version I get the software to deploy to the robot but the robot doesn't
work anymore. Jaquars are blinking. All electrical connections are fine.
I followed the directions to update the software is there something that is missing?
(6,359 Views)
Hey AustinTech,
If you've successfully updated LabVIEW, the driver station, and the cRIO and are still seeing this issue, the most common issue is that the project is bound to an older build.  The easiest way to verify this is to create a new project and copy all of your VIs into said project.  This will force LabVIEW to use the most recent files.
-John S.
-John Sullivan
Problem Solver
(3,054 Views)
Do you see "No Code" on the driver's station?  If so you are suffering the same issue our team is most likely.
http://decibel.ni.com/content/thread/2321
I am trying a different laptop tonight to see if that makes a difference.
Thanks!
Randy
(3,054 Views)
