FIRST Robotics Competition Discussions
Runs but get 'No Code' when deployed
We have code that runs from LabView and can successfully deploy as the startup, but on rebooting, the Driver's Station stubbornly shows 'No Code'.  Any suggestions?
Message 1 of 17
(13,977 Views)
What is printed on the serial console?
Message 2 of 17
(4,520 Views)
Looking for a serial cable->USB connector!  Here is the link to our code:  https://www.yousendit.com/download/bFFOM25ERndVbSt4dnc9PQ
Would there be any clues in our install.txt from the last re-imaging?
System image applied Apr 7 02:28
ASC /FRC_ImageVersion.ini size: 197
ASC /install.txt size: 6277
ASC /ni-rt.ini size: 2332
BIN /niwebserver.conf size: 35
BIN /persist.pal size: 0
ASC /ni-rt/startup/startup.aliases size: 67
BIN /ni-rt/startup/startup.rtexe size: 9272
BIN /ni-rt/system/config.cdf size: 19176
BIN /ni-rt/system/config.old size: 0
BIN /ni-rt/system/criosd.out size: 366436
BIN /ni-rt/system/debug.o size: 2632
BIN /ni-rt/system/FRC_FPGA.out size: 185302
BIN /ni-rt/system/FRC_FPGA_invariant.bit size: 959207
BIN /ni-rt/system/FRC_FPGA_runtime.bit size: 959207
BIN /ni-rt/system/FRC_NetworkCommunication.out size: 112401
BIN /ni-rt/system/ftpserve.out size: 51902
BIN /ni-rt/system/libexpat.out size: 73645
BIN /ni-rt/system/libiconv.out size: 53928
BIN /ni-rt/system/lvalarms.out size: 112274
BIN /ni-rt/system/lvanlys.out size: 866415
BIN /ni-rt/system/lvblas.out size: 77751
BIN /ni-rt/system/lvrt.out size: 3915564
BIN /ni-rt/system/lvuste.out size: 1696
BIN /ni-rt/system/nbfifo.out size: 44760
BIN /ni-rt/system/NetConsole.out size: 10760
BIN /ni-rt/system/ni_emb.out size: 45396
BIN /ni-rt/system/NiFpga.out size: 110068
BIN /ni-rt/system/niorba.ocm size: 640
BIN /ni-rt/system/niorbs.out size: 118751
BIN /ni-rt/system/nipals.out size: 389577
BIN /ni-rt/system/niriorpc.out size: 68644
BIN /ni-rt/system/niriosrv.out size: 427260
BIN /ni-rt/system/nirpcs.out size: 101600
BIN /ni-rt/system/niserial.dbs size: 177
ASC /ni-rt/system/niserial.ini size: 939
BIN /ni-rt/system/niserial.out size: 207317
BIN /ni-rt/system/nisvcloc.out size: 36484
BIN /ni-rt/system/nivision.out size: 3813943
BIN /ni-rt/system/NiViSrvr.out size: 61279
BIN /ni-rt/system/nivissvc.out size: 1246518
BIN /ni-rt/system/NiViSv32.out size: 92088
BIN /ni-rt/system/nvdata.bin size: 48
BIN /ni-rt/system/registry.out size: 47512
BIN /ni-rt/system/rtapp.rsc size: 197190
BIN /ni-rt/system/rtvarsup.out size: 99856
BIN /ni-rt/system/settime.out size: 2368
BIN /ni-rt/system/startuppatch.out size: 47781
BIN /ni-rt/system/target.out size: 101592
BIN /ni-rt/system/tdms.out size: 155960
BIN /ni-rt/system/ts_dio.out size: 43110
BIN /ni-rt/system/ts_rtc.out size: 36480
BIN /ni-rt/system/ts_sntp.out size: 61394
BIN /ni-rt/system/tsengine.out size: 85575
BIN /ni-rt/system/visa32.out size: 59557
BIN /ni-rt/system/VisaCtrl.ocm size: 285
BIN /ni-rt/system/VisaCtrl.out size: 16252
BIN /ni-rt/system/vx_exec.out size: 424825
BIN /ni-rt/system/vxfpsup.out size: 2256
BIN /ni-rt/system/vxWorks size: 4161889
BIN /ni-rt/system/errors/chineses/niorb.err size: 1604
BIN /ni-rt/system/errors/English/analysis.err size: 32471
BIN /ni-rt/system/errors/English/labview.err size: 197062
BIN /ni-rt/system/errors/English/lvfpga.err size: 27726
BIN /ni-rt/system/errors/English/measure.err size: 764
BIN /ni-rt/system/errors/English/nicrio.err size: 22127
BIN /ni-rt/system/errors/English/niorb.err size: 2008
BIN /ni-rt/system/errors/English/nipal.err size: 26008
BIN /ni-rt/system/errors/English/niriofcf.err size: 7887
BIN /ni-rt/system/errors/English/reports.err size: 1023
BIN /ni-rt/system/errors/English/VISA.err size: 13597
BIN /ni-rt/system/errors/French/lvfpga.err size: 31654
BIN /ni-rt/system/errors/French/nicrio.err size: 24875
BIN /ni-rt/system/errors/French/niorb.err size: 2108
BIN /ni-rt/system/errors/French/nipal.err size: 27483
BIN /ni-rt/system/errors/French/niriofcf.err size: 8732
BIN /ni-rt/system/errors/French/VISA.err size: 14913
BIN /ni-rt/system/errors/German/lvfpga.err size: 31177
BIN /ni-rt/system/errors/German/nicrio.err size: 23737
BIN /ni-rt/system/errors/German/niorb.err size: 2060
BIN /ni-rt/system/errors/German/nipal.err size: 28291
BIN /ni-rt/system/errors/German/niriofcf.err size: 9146
BIN /ni-rt/system/errors/German/VISA.err size: 14792
BIN /ni-rt/system/errors/Japanese/analysis.err size: 31831
BIN /ni-rt/system/errors/Japanese/labview.err size: 201044
BIN /ni-rt/system/errors/Japanese/lvfpga.err size: 27810
BIN /ni-rt/system/errors/Japanese/measure.err size: 742
BIN /ni-rt/system/errors/Japanese/nicrio.err size: 22646
BIN /ni-rt/system/errors/Japanese/niorb.err size: 1906
BIN /ni-rt/system/errors/Japanese/nipal.err size: 24403
BIN /ni-rt/system/errors/Japanese/niriofcf.err size: 7968
BIN /ni-rt/system/errors/Japanese/reports.err size: 1103
BIN /ni-rt/system/errors/Japanese/VISA.err size: 13352
BIN /ni-rt/system/errors/Korean/nicrio.err size: 22127
BIN /ni-rt/system/errors/Korean/niorb.err size: 1857
BIN /ni-rt/system/errors/Korean/nipal.err size: 22903
BIN /ni-rt/system/errors/Korean/niriofcf.err size: 7887
BIN /ni-rt/system/errors/Korean/VISA.err size: 13076
ASC /ni-rt/system/ethernet/netconf.ini size: 156
BIN /ni-rt/system/vxipnp/VxWorks/bin/NiEnAsrl.out size: 74152
BIN /ni-rt/system/vxipnp/VxWorks/bin/NiViAsrl.out size: 53733
BIN /ni-rt/system/vxipnp/VxWorks/bin/NiViEnet.out size: 80644
BIN /ni-rt/system/vxipnp/VxWorks/bin/NiViPxi.out size: 58786
BIN /ni-rt/system/vxipnp/VxWorks/bin/nivirio.out size: 89968
BIN /ni-rt/system/vxipnp/VxWorks/bin/NiViUsb.out size: 52951
ASC /ni-rt/system/vxipnp/VxWorks/NIvisa/Visaconf.ini size: 469
ASC /ni-rt/system/vxipnp/VxWorks/NIvisa/Passport/nivirio.ini size: 139
ASC /ni-rt/system/vxipnp/VxWorks/NIvisa/Passport/nivisa.ini size: 525
ASC /ni-rt/system/www/Beyond.htm size: 2276
ASC /ni-rt/system/www/Docs.htm size: 6828
BIN /ni-rt/system/www/favicon.ico size: 1406
ASC /ni-rt/system/www/Index.htm size: 2480
ASC /ni-rt/system/www/Overview.htm size: 3372
ASC /ni-rt/system/www/Services.htm size: 4453
ASC /ni-rt/system/www/Webtool.htm size: 4588
BIN /ni-rt/system/www/www.css size: 371
BIN /ni-rt/system/www/images/Home.gif size: 1009
BIN /ni-rt/system/www/images/Homed.gif size: 944
BIN /ni-rt/system/www/images/Lvwebsrv.gif size: 4174
BIN /ni-rt/system/www/images/Next.gif size: 974
BIN /ni-rt/system/www/images/Nextd.gif size: 928
BIN /ni-rt/system/www/images/Panel.gif size: 3438
BIN /ni-rt/system/www/images/Panldiag.gif size: 9394
BIN /ni-rt/system/www/images/Prev.gif size: 975
BIN /ni-rt/system/www/images/Prevd.gif size: 928
BIN /ni-rt/system/www/images/top.gif size: 974
BIN /ni-rt/system/www/images/up.gif size: 974
Message 3 of 17
(4,520 Views)
If the current project was created in January before the last LV update  (and we DID update), would that be a potential cause of a build crash?
Message 4 of 17
(4,520 Views)
You also need a null-modem adapter to use the serial console.
Alternately, you can use the NetConsole software. Follow the directions about halfway down from here: http://first.wpi.edu/FRC/frccupdates.html
Message 5 of 17
(4,520 Views)
Does it crash or just not run?
Not having the correct update shouldn't cause a crash when you try to deploy the code.
Are any of the dip switches (particularly the No App or Safe Mode) flipped? The No App and Safe Mode switches would prevent any code from running on start up.
Message 6 of 17
(4,520 Views)
Will NetConsole work with the LabView imaging?
Message 7 of 17
(4,520 Views)
Crash or Not Run? I guess that's the real question....the NoApp and Safe switches are in the proper position.
Message 8 of 17
(4,520 Views)
Does it have problems with running the default code?
Message 9 of 17
(4,520 Views)
Nope
Message 10 of 17
(4,520 Views)
