FIRST Robotics Competition Discussions
RoboRio will not communicate over USB
I have same experience on Labview(ECM)2017 after updating to windows10 from win7. I could not re-install right USBLAN driver(nationalinstrumentsblan.sys) so I  tried .to rename to usbnet.sys. It become connecting is good. However IP address become 169.254.1.2 instead of 172.22.11.2.
 In my case, this change causes others issues in coding.
Can you find a way to assign original address(172.22.11.2)?
M.naka
Message 11 of 12
(981 Views)
M.naka,
If you're using a roboRIO with FIRST, it sounds like you're using odd software choices.  We'll want to get you fixed there first.  Can you create a new thread to get focused help with your issue?
If that's not what you're doing, you'll want to go to the normal forums rather than the FIRST forums.
Message 12 of 12
(976 Views)
