‎01-23-2012 12:45 PM
Does this cause any differences in the controllers visibility in MAX? I would also make sure you have any firewalls on your machine turned off as they may block the IP address assigned to the cRIO after an IP Reset.
‎01-23-2012 12:53 PM
All of the firewalls are turned off and I still can't see the cRIO
‎01-23-2012 01:18 PM
Can you comment on the results of these steps:
Some other things to try would be to disable or enable your wireless card or other NICs (whatever the opposite of what is now). Additionally I would try connected to the cRIO through a hub or switch instead of directly to your PC.
To clarify your current setup,
You can firewalls off, IP has been reset (status light is flashing), your computers ethernet NIC is set to dynamically acquire an IP Address from a DHCP server (in this case a link local address), and we still don't see anything in MAX under remote systems?
‎01-23-2012 01:20 PM
Yes, and the wireless is disabled.
‎01-23-2012 03:50 PM
I would prioritize hooking up a null modem cable (you can make one with just 3 wires:http://www.lammertbies.nl/comm/info/RS-232_null_modem.html) to see what the IP address of the cRIO is currently set to. If you haven't tried running through a switch yet (even just using the bridge that comes with the KoP is fine) also give that a shot.
‎01-24-2012 12:51 PM
We do not have access to a computer with a serial input, would I be able to use a female serial to usb cable?
‎01-24-2012 12:55 PM
You should be able to go from the crio->null modem serial cable ->serial to usb converter.
‎01-24-2012 01:01 PM
I found somthing that might fix this, "NI Ethernet Configuration" "This device uses DHCP and is configured to use the host name "GottaGo". However, the DHCP server assigned it the hostname "(<". Your device must be cofigured with a valid hostname to function properly"
‎01-24-2012 01:08 PM
Where are you seeing this message? Could you provide a screenshot?
‎01-24-2012 01:14 PM
It's in the MAX screen "NI Ethernet Device Configuration" I changed it to a valid name and set the ip to 10.27.95.6 but I am unable to veiw the device in remote systems.
